Need this to figure out if a modem would be supported?
Solved! Go to solution.
Highly recommend using embedded SIM models if you have them working in your region. As noted earlier in this thread working alternative is Skyus DS but its "yet another box" to your network.
USB dongles are a pain to handle with overheating etc.
Maybe we get some magic on Nov 5th on this...
