MX device License claim issue.
Ayush_Oberoi
While claiming my adv security license in the dashboard i encountered the below message.
"License Z***-****-9*** is an Advanced Security license, but your organization’s existing license is for SD-WAN. If you wish to upgrade your Advanced Security license, please contact Support".
I am not sure which license is my organization is using.
as per above should i go ahead with which of the following license below.
LIC-MX95-SDW-3Y
LIC-MX95-ENT-3Y
Looking forward for your inputs.
Regards.
RWelch
LIC-MX95-SDW-3Y would be the right one.
RWelch
Brash
LIC-MX95-SDW-3Y is the SD-WAN Plus license.
You can contact support to upgrade the advanced security license to an SD-WAN Plus license.
The upgrade will remove some of the time on the license to compensate for the feature change.
Ayush_Oberoi
I understand that LIC-MX95-SDW-3Y is an SD-WAN Plus license. However, could you please let me know if this is the correct license to overcome the following error?
"License Z**-**-9* is an Advanced Security license, but your organization’s existing license is for SD-WAN. If you wish to upgrade your Advanced Security license, please contact Support."*
Yes, but you can't have two different MX license types coexisting at the same time. You'll need to contact Meraki support.
