@cmr
Thank you for the proposition! If I understood it correctly, it would look something like this:
I like it since if I had designed the solution from scratch, it would have probably done something similar. We were however given the equipment and told to do the best with what we have, so, as you can imagine I'm trying to come up with something that involves the existing hardware before we ask for some additional. 🙂
So I guess my question would be if this could be achievable with something like this:
MX100s would still be terminating the VPN tunnels to branch locations on the L2 network while MX250s would, I guess, perform some kind of policy-based routing in a way that everything meant for branch communication would go on the WAN2 interface while all other traffic would go to WAN1.
Do you think this is a viable solution at all? Will we run into some VRRP, STP, or simply general connectivity problems with this topology?
Best regards
