MX autoVPN with BGP - Default route not advertised
I have been testing using BGP between MX and our DC L3 switch. I do not get the 0/0 default route advertised. If I enable the "ipv4 default route" or exit hub none of the 0/0 defaults in the routing table gets advertised.
How do I get the local MX to send the auto generated default route via BGP?
I think you get this backward. The intention of the BGP implementation on MX is to provide the spoke routes to some infrastructure. So all your spoke networks that participate in autoVPN will be injected into BGP and given to it's configured neighbor.
The clicking of default route in the VPN page is meant for branches to use that MX as a full tunnel endpoint to reach all other destinations.
The upstream infrastructure needs it's own way to reach the internet outside of the BGP implementation on the MX.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_1b57be60c4aee7","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_1b57be60c4aee7_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_1b57be60c4aee7_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_1b57be60c4aee7_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_1b57be5b528187","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
