MX WAN Failover
leadtheway
MX WAN Failover
Have several MX appliances, mix of 84 and 100's.  Setting up backup internet connections on the 84 seemed straightforward, just edit WAN 2.  I'm not seeing similar option on 100?  is there a trick to it, i don't see where i can toggle one of the interfaces for WAN. Also, is there anything special about any settings for the failover or is it just plug and play
NolanHerring
I believe you need to access the local status page of the MX100, and change I believe LAN 2 to WAN 2 and save that.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
6 Replies 6
NolanHerring
TwitterLinkedIn
leadtheway
so I need physical access?  and does it have to  be port 2 or can it be any?
NolanHerring
If it is already on the cloud (online) you do not need physical access.
You can access the local status page remotely
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Using_the_Cisco_M...
TwitterLinkedIn
NolanHerring
And I believe it can only be LAN 2 converted to WAN 2
TwitterLinkedIn
BrechtSchamp
The MX100 has a dedicated management interface to access the local web page, but I think you can also access the local webpage when you have L3 access to the LAN IP of the MX. For that you'll have to set "
Remote device status pages" to "Enabled" in Network-Wide > General.
The docs specify the following:
You can toggle the LAN2 port between LAN and Internet, through Uplink configuration under the Local status tab.
Source:
https://documentation.meraki.com/MX/Installation_Guides/MX100_Installation_Guide
So only LAN Port 2.
I know this is closed but with the 15.x firmware this now can be done through the web GUI.  Tested in 15.14 and 15.15
