MX - VRFs 26.1.2
RaphaelL
MX - VRFs 26.1.2
Hi ,
So VRFs are finaly here on MX. I just deployed MX 26.1.2 on my C8121
What's new
  • Added support for configuring Virtual Router Forwarding domains (VRF) through the Early Access feature program.
So that's true , I can configure the VRFs from the page Organization -> VRFs
But according to my dashboard and documentation : https://documentation.meraki.com/SASE_and_SD-WAN/MX/Design_and_Configure/Configuration_Guides/Networ...
  • VRFs are supported on MX 26.1.3+ in Routed Mode.
  • 7 VRFs can be configured within a dashboard organization to be used in addition to the Default VRF.
So TL;DR , I can configure VRFs but not use VRFs at the moment , am I missing something ?
Is the limit 7 custom VRFs + default = 8  or  6 custom VRFs + default = 7 ? The messages are misleading for a non-native english speaker.
5 Replies 5
Inderdeep
Good, Finally
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
Ryan_Miles
Meraki Employee All-Star
Limit is 8. If you attempt to add more it produce this.
RaphaelL
Were you able to configure a VRFs on a vlan ?
I think I have to wait for 26.1.3 to test it out
DarrenOC
@RaphaelL , @Ryan_Miles - is 8 a hard limit for just the MX or for a Network?
RaphaelL
8 VRFs appears to be the hard limit for an org at the moment.
