MX VPN Routed
sjlee
MX VPN Routed
When configuring LAN ports on MX equipment operating in Routed mode, only subnet/IP addresses can be set in the Single LAN option, and subnet/IP addresses/port can be set in the VLANs option, but the port can only be set in trunk/access mode.
Is it impossible to set the LAN port as L3 Routed Port?
I tried searching for Routed port settings on MX equipment, but I can't check the similarities.
Please answer it.
Thank you,
Best Regards.
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Layer_2_Functionality
Mx does not support L3 ports on lan.
You can use vlan SVI , attached to a access port.
1 Reply 1
