How to connect 2 MX on a 2 MS CORE Switch without aggregate ?
dimatt
I would like to do this configuration:
I have 2 MX for Wan redundancy, and a CORE STACK with 2 MS.
I need a trunk between the MX and MS because MX does inter-vlan routing.
How can i connect the stack to the 2 MX without creating a loop, because MX doesn't support aggregate ?
Trunk all ports with the same vlans to the switches.  Make sure the switches have the spaning-tree protocol  enabled on the ports to mx/other swtiches
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Layer_2_Functionality#Spanning_Tree_Prot...)
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair#Fully_R...)
Brash
If you cable the topology this way, it will work but spanning tree will disable one of the ports in order to prevent a loop (the MX will pass along the bpdu's).
dimatt
The 2 differents MX ports have the same MAC address ?
dimatt
thanks for the links.
