MX Uprade to 14.35
MX Uprade to 14.35
Is anyone else getitng these messages?
On xxx, between yyy, the firmware for the security appliances in the network "zzz - appliance" will be upgraded to MX 14.35.
The very latest beta software available is 14.34.  I wonder if it was meant to say 13.35 instead.
12 REPLIES 12
BlakeRichardson
Re: MX Uprade to 14.35
Mine is saying one of my networks MX is running 14.35... I don't have an MX on that network
NolanHerring
Sure did. Was only on my testing unit which happened to be running 14.x code
Nolan Herring | nolanwifi.com
TwitterLinkedIn
jdsilva
Yup, seems to be a big push to get to 14.35 from Meraki. This firmware makes me happy because they FINALLY fixed the MX warm spare blackholing traffic traffic problem in this version. I'm guessing something else big was fixed, hence the push.
jdsilva
Yeh... If Meraki wants to do an upgrade, and there's no devices in that network, they just do it.
I feel a critical security announcement coming out in a week ...
MacuserJim
I had that show up for a bunch of networks, I would love to read through the release notes about it...
jdsilva
@MacuserJim Here you go:
Thanks for that.  The shards that I can see still do not show 14.35 or the change log.
Ben
I cannot even see 14.35.
Versions of MX i can see are 13.33 - 13.36 (stable release candidate) and Beta 14.34.
RichG
One of my networks has been scheduled by Meraki to get 14.35 but for another of my networks it isn't an option. Both networks show the changelog if I click 'Next version' from the 14.34 changelog.
It may have to do with tickets that were opened in that network.  The second changelog entry covers one of the tickets I had open for the network that is scheduled.
I also noticed in the Other section that they are removing the automatic four hour reboot with no uplink.  It would be nice if this were a configurable option.  For most of our devices this will be good, but we have some remote devices that will now have to be manually power cycled if the uplink changes.
jdsilva
...And 14.36 is out now. That's a fast one for MX.
cg
I've hit the mentioned OSPF bug multiple times on 14.35.   It's a pretty major issue to lose your IGP, I definitely wouldn't recommend anyone using it to upgrade to that firmware.  14.36 does seem to have resolved it for me.
