MX Temperature
guitb
MX Temperature
We encountered a problem where a spoke MX appliance lost connectivity. Upon investigation, the device was found to be excessively hot. Rebooting the appliance restored connectivity.
Is there a method to obtain temperature readings or electrical data for MX 68 appliances?
6 Replies 6
RaphaelL
Hi ,
If you go to Organization -> Summary Report -> Select this network , do you see anything anormal to the device utilization prior to the reboot ?
guitb
Utilization was at 3% and health score was 100/100.
Not specifically about the temperature, only the use of the device as mentioned.
The ideal is to install the equipment in a place that is properly cooled.
I have seen this issue many times with MX65s. It was related to PoE. Moving the PoE devices off the MX65s usually fixed it (or having them RMA'd).
I have never seen it happen on an MX68.
DarrenOC
@PhilipDAth - yep, they were nice little hand warmers
jbright
 I have found that applying an external heat sink with double-sided thermal tape seems to help with the heat issues on the MX6x series. Here's a link to the heat sink I have been using:  https://www.amazon.com/dp/B07X9L2SRP
