MX SD wan and Maximum number of branch support?
Abhishek7310
Just browsing
I need to deploy MX devices in place of MPLS line to reduse the cost
there is one HO with 70 Systems and 30 branch (each 5 to 10 system)
I'm totally looking for SD wan solution in Meraki
Suggest me which device should i go for i shortlisted 4 devices and also wants to know whats the maximum HO  to branch conectivity for SD Wan?
For Small Branch
MX64
MX67
Medium Branch or HO
MX84
MX100
pl advice
This is the MX sizing guide:
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_mx_sizing_guide.pdf
The MX84 will be fine for your head office.
I tend to use either MX67 or MX68 for small sites.
The advantage of the MX68 is it has a 10 port LAN switch built-in (and two of those ports are PoE).  So if your site has fewer than 10 devices to plug in you don't need a separate switch.
2 REPLIES 2
DarrenOC
Hi @Abhishek7310 , what connectivity do you have at your Head Office\Data Centre? I would consider the MX250 as there isn’t that much of a price jump from the MX100 to the MX250 especially if your Cisco Partner has deal registered this for you. Just my 2 cents
Darren O'Connor | uccert.co.uk
