MX OSPF support
iores
MX OSPF support
as of today, does Meraki still supports only advertising AutoVPN routes to OSPF neighbor? I have hub and spoke topology, and would like to advertise AutoVPN subnets from hub to the upstream L3 switch.
5 Replies 5
iores
What do you mean with "on the lan side"?
Take a look at the documentation.
https://documentation.meraki.com/MX/Networks_and_Routing/Border_Gateway_Protocol_%28BGP%29
JeroenVercoulen
It only supports OSPF on the LAN side of the MX when using single-LAN settings. But it only supports AutoVPN route distribution to Layer3 uplink devices. It does not learn routes from the Layer3 device.
https://documentation.meraki.com/MX/Site-to-site_VPN/Using_OSPF_to_Advertise_Remote_VPN_Subnets
If you want bidirectional routing you need to use BGP as mentioned above.
iores
@JeroenVercoulen
But OSPF on the LAN side is enabled only if MX is in routed mode, right? Can AutoVPN subnets be advertised over LAN port if MX is in concentrator mode?
