Hi All, (thanks Chris and Inderdeep for your quick reply )
is Cisco Meraki firewall MX68 can work with FortiGate 201F ?
Site-to-Site VPN
or Hub-and-Spoke
or Remote Access
or Custom
How to inter oper easily ?
Thanks for the very useful and readable link Fred de Jonge | Fortinet to Meraki site-2-site VPN
Kinds, regards
Vincent
Solved! Go to solution.
Yes of course they can .. Are you talking about the Site to site VPN between them ?Here you gohttps://freddejonge.nl/fortinet-to-meraki-site-2-site-vpn/
That's what's called an open question, right? 😉
Yes, of course. Both of them speak TCP/IP. What exactly are you referring to? Site-to-Site VPN perhaps?
