MX250 FIPS140-2
MelissaJL
MX250 FIPS140-2
We recently purchased a Meraki MX250.  Not cheap!  Now, the state is telling us that we are not compliant because it is not FIPS140-2 certified.  I have been reading for 2-1/2 years now that the MX250 was going to become certified.  We are now in 2021 and nothing Meraki appears on the certified list.  When will this happen, or do I have to get rid of MX250 and look for another provider?  Thanks.
Once 15.x gets declared a stable release 16.x should become available.
8 Replies 8
MX16 is your friend, it is on the FIPS list, we expect MX15 to be moved from beta to release imminently and MX16 should then be available.  I'd hold on a short while and ask your Meraki AM for a more accurate timetable.
We have version 14.53 released in June 2020.  It doesn't give me the option to upgrade to firmware version 15 or 16.XX.  Is it possible?
Thank you for the information!
15.42 is in the beta channel, we've been running 15.x for over 18 months on our production MXs including an HA pair of MX250s.  We expect it to become a stable release very shortly.
Thank you!  Thank you!  Thank you!  I downloaded this certifications.  This helps a ton!
