MX Dynamic Routing
JPScolar
MX Dynamic Routing
Is Dyanamic routing on the MX supported in NAT mode or only on VPN Concentrator mode?   I have heard that the BGP support on the MX is lacking a bit, for instance to set eBGP connectivity  to non-Meraki networks.  Any comments/advice on this?
Thank you.
Juan-Carlos Perez
Ospf can be used in both modes. But only advertise networks.
Bgp is currently only available in 1 armed concentrator mode
One more thing.
Note: MX devices in Routed mode only support OSPF on firmware versions 13.4+, when using the "Single LAN" LAN setting. OSPF is otherwise supported when the MX is in passthrough mode on any available firmware version. This can be set under Security & SD-WAN > Configure > Addressing & VLANs.
Note: The MX will only advertise Meraki Auto VPN routes. The MX does not learn routes advertised by any OSPF neighbors.
Note: To achieve symmetrical routing between spoke MXs participating in AutoVPN and OSPF peers, the hub MX will need to have static route(s) configured for any subnets local to the OSPF peer, which will have to be advertised in the AutoVPN mesh (by switching the VPN mode for those particular static rotue(s) to Enabled).
RaphaelL
Also in routed mode via a private beta an MX 18.205
