Anyone know how to monitor a "client" across the VPN tunnel. I have a MX that is tunneled to a Checkpoint firewall. I'd like to setup something like the feature in Network Wide>Alerts>Clients connect or disconnect from the LAN for one of the clients across the VPN tunnel? Any hack/workaround or other ideas would be appreciated.
