MX 84 in one armed concentrator mode showing high number of clients.
guerriero33t
I have a VPN concentrator in a datacenter set up as one armed. When I go to the clients list I show thousands of clients. Is this normal?
2 Replies 2
DarrenOC
Yes and no!  Is the MX in its own network?  If not move it into its own network and that should clear the anomaly.
DarrenOC
Hi @guerriero33t  - apologies, ignore the last snippet.  Take a look through this document:
https://documentation.meraki.com/MX/Monitoring_and_Reporting/Client_Tracking_Options#Requirements_an...
How are you tracking clients?  We got caught out by the following:
  • Do not use Unique Client Identifier in a dashboard network where the MX's WAN ports are connected to a Meraki switch in the same Dashboard network. If you need to use a Meraki switch in between your ISP and the MX WAN please separate this switch from both the dashboard and physical network.
