MX-68: remove subnet IP VLAN 1
FDM
How can i remove the subnet configured on VLAN 1?
I cannot set it to empty then i get an error VLAN must be in IP address range CIDR format.
I do not want to assign an IP address to VLAN 1 that is what i am trying to accomplish.
The native VLAN can remain on 1.
Kind regards,
Frederik.
6 Replies 6
Not possible.
How about you remove it and set drop untagged on the trunk port
FDM
It does not allow me to remove it.
GIdenJoe
Then set the other VLAN to native 😛
GIdenJoe
Make sure you have another VLAN interface on the MX and delete the VLAN 1 interface afterwards.
FDM
Hi Joe,
This is what I did but is not possible i think due to the faxt the native vlan is set to 1.
Give it a non-routable link-local address.  Like 169.254.0.1/30.
