When reviewing the release notes for 15.42.1, I found myself wondering if they covered all of the changes between 14.51 and 15.42.1, or just the changes between 15.42 and 15.42.1
Is this the case, or do I need to review every release between these two MX software versions to understand the scope of the changes/feature enhancements/gotchas?
Solved! Go to Solution.
@Crocker : Mainly if you see the Mx 15 feature highlights which is not there in 14.51
Fixed issue in 15.1 which was there in 14
Features added in 15.11
Features added in 15.42.1
all versions in between are beta versions.
@Crocker : 15.42.1 is simply 15.42 just have a look below
https://community.meraki.com/t5/Security-SD-WAN/New-MX-firmware-15-42-1-release-channel/m-p/114407
@Inderdeep Thanks for passing that along.
I guess I should clarify what I'm asking. All of our MX/Z3 devices are running MX14.51, at some point soon we're going to want to update to the latest stable release (15.42.1).
I want to review all of the changes, enhancements, and gotchas between those versions - preferably in one place vs. going through every set of release notes between 14.51 and 15.42.1. If there is a way to do so, that is.
