MG51 connection speed mix with MX95
Jyrki_Halonen
I have MG51 router port 1 connected to MX95 WAN port 4.
When checking port connection speeds from both devices, result looks like:
- MG51 port 1: connected 10 Mpbs Full duplex
- MX95 WAN port 4: connected 2,5 Gpbs Full duplex.
Is this UI bug or which speed information is correct?
ConnorL
Meraki Employee All-Star
It's a UI bug, it should be resolved in MG 3.101, in the change log you'll see:
Corrected Dashboard UI issue where MG51s would display their link speed as 10 Mbps when connected at 2.5 Gbps
If you still encounter this, please open a Support case.
2 Replies 2
ConnorL
Jyrki_Halonen
I updated to 3.101 and now UI shows the speed correctly, thanks.
