Is there a way to enable MFA for Cisco VPN?
Solved! Go to solution.
Hi @RGrayTpT,
I think that this link can be helpful:
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance/Authentication
It depends about which Client VPN you are talking - IPsec VPN or Anyconnect?
Meraki doesn't support it natively, but it is possible to integrate with 3rd party authentication solution which will provide another factor auth. (https://documentation.meraki.com/General_Administration/Other_Topics/Two-Factor_Authentication)
Thanks! I found a few old forum topics with good suggestions as well.
