Elon Thank you.
To bypass the router, go to the App home page > Settings > Advanced
Starlink App version must be at least 2.0.19 to work
The toggle button on to bypass the Starlink router
This allows you to completely disable the Starlink Wifi Router.
You would need to utilize a Starlink ethernet adapter in order to plug in your own equipment.
While Bypass mode is enabled, router commands will not work.
If the toggle switch does not appear in the Settings tab, can factory reset the router and/or delete and re-download the app.
App Message in red text when Bypass is enabled: "Bypass Mode will completely disable the built-in Starlink Wifi router. this is an advanced feature that requires a Starlink Ethernet adapter and your own network equipment. A manual Factory reset will be required to reverse this."
