List of MX's and their WAN IP?
MerakiMed
Is there a way to get a list of all my MX's and their effective WAN IP?
Ryan_Miles
Org Overview page > Devices tab > enable Uplink IP port 1 & 2 columns. And you can export to csv if needed.
Ryan / Meraki Solutions Engineer
6 Replies 6
Ryan_Miles
Thanks much. That Devices tab is kind of faded. I had to really look for it! 🙂
Ryan_Miles
You can also get it via API uplink statuses call if you're looking for an API option
Make_IT_Simple
Meraki Alumni (Retired)
The only way to achieve that is to use API: https://developer.cisco.com/meraki/api-v1/
DarrenOC
As above ^^ API call
As @Ryan_Miles says.
