Virtual MX
tantony
Virtual MX
My company is expanding, and we might be moving to a second building.  This means I need another MX for site-to-site VPN.  I'm also looking into the possibility of a virtual MX appliance, but I know anything about this.  From what I know, this can be hosted in AWS, Azure, etc.  But how does the physical connection happen?
Make_IT_Simple
Meraki Alumni (Retired)
There is no physical connection. The virtual MX will be hosted in the cloud and you will use auto VPN to connect it to your physical MX. If you are expanding, you will probably need a second physical MX, and if need be, the virtual MX to access your server in the cloud.
2 Replies 2
Make_IT_Simple
tantony
Thanks, I do prefer a physical MX like I have now, but just wanted to know the virtual MX instance works.
