Licensing
Eugenios
Licensing
Hi team,
IHAC with an MX and advanced license at their HQ site
On a remote site they need a new one
The traffic will go through HQ, so I only need s2s
Do I need to purchase the second unity with, say an Enterprise License?
DarrenOC
Hi @Eugenios
You will require an Advanced Security licence for the MX unit at your second site as you can't mix Enterprise and Advanced licences within a single Organisation.
You could create a secondary Org and place the second MX in that and run an Enterprise licence but you'll have to manually create the s2s VPN.
5 Replies 5
Inderdeep
Have a look on the license FAQ
https://documentation.meraki.com/General_Administration/Licensing/Meraki_MX_Security_and_SD-WAN_Lice...
I think the basic license is enterprise license and you should need it. Meraki will not work without license.
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
DarrenOC
Hi @Eugenios
Eugenios
Thank you - good point on the manually configuring the s2s VPN
DarrenOC
cost vs functionality/administration overhead. 😁
GreenMan
Meraki Employee All-Star
Secure traffic processing really happens on the local MX, where clients are connected - you will get limited protection, if you're relying on just the VPN Hub to (Advanced Security) process the traffic.   You most likely need Adv Sec for the Spoke.   This is one reason why we simplify everything to the same license level, per Org.
