L3 firewall hit count 0
James12
Hi folks,
have you guys encounter 0 hit count on the L3 firewall rules?
I wanted to see the rule's usage and effectiveness.
Even the default rule is stated as 0.
so, it making me confuse.
looks like its depends on the browser.  in chrome it doesn't go to 0 but keeps counting. but in duckduckgo browser it reset to 0 after a count.
i also only have hits on the allow any any.
looks like a gui bug.
8 REPLIES 8
DarrenOC
Hi @James12 , to me that indicates that the traffic you’re looking for isn’t hitting your firewall!  Do you have another route out of the network?
It can take a few seconds for the counters to increase especially after a page refresh.
@DarrenOC no only 1 simple network, MX is the gateway.
I waited for the page to load the hit count for over an hour but never came up.
My access to the internet is totally accessible, so that puzzles me.
DarrenOC
What’s your model and firmware?
Have you also tried verifying the behaviour from another browser?
@DarrenOC
MX 64
V15.42.2
I just switch to Firefox and edge to test out, only hitting the default rules
I just added ICMP rules to google DNS and place it on the top. it doesnt show too.hm...... James12_0-1629704715929.png
the allow any also works.
you should look closely because its realtime and it can jump from value x to 0 if there is not much traffic
James12
@ww so the hit count will just reset to 0 when there is no traffic?
James12
@ww I'm using chrome, I don't see any hit count.
using firefox and edge only sees default rules with hit count.
Even adding a deny-all at the last policy.
I set up a test IP to see the hit count.
it only shows 0
Just frustrating not Meraki is not able to show it what it does.
Hard for me to documents and pass them on to my colleagues.
