@Bruce
this
“So for PCs, etc. that only need one VLAN you use an access port and specify the VLAN, and the host doesn’t need to know anything about VLAN tags (the VLAN is defined by the port setting).”
this requires an L3 switch if I want to single out a port on a switch for use on my client vlan (4) while my default is, say, 1. On an L2 switch all ports come out as whatever the default VLAN is on the last upstream port capable of setting a default VLAN is.
“Where you need multiple VLANs, like to an access point or another switch, you use a trunk and the device needs to be able to tag traffic correctly - like an access point does.”
Yea - which is great if I’m just doing a bunch of MRs. But my situation is somewhat fluid in the sense that at any given moment I may need to change a room from just having an MR in it to being a lab with 5 wired clients plus that MR. So the MR’s port would be trunk and SSID routed to VLAN 4, and the ports for all the wired machines would need to be flipped to access ports where VLAN 4 is the default so that all the clients join 4 without needing a virtual interface set up in their network config. All that make sense?
