July 2018 Meraki Quarterly & BGP Call for Beta users
Hi All,
Meraki's quarterly is coming up again in about 12 hours, on July 12 at 9am (Pacific Time)
https://meraki.cisco.com/webinars/signup/2211/cisco-meraki-quarterly-update/10535
Among other things, we will be doing a call for BGP beta users. If you are interested to join lots of other customers in this beta, to see the benefits of BGP, you can request it using the below link, or connecting with your Meraki rep.
BGP Beta Link:
https://goo.gl/forms/6GS5phgPJGYaQxge2
Looking forward to seeing you on the quarterly!
Accepted Solutions
Re: July 2018 Meraki Quarterly & BGP Call for Beta users
Hi All,
Apologies. Form should be working now 🙂
7 REPLIES 7
Link says:
You need permission
This form can only be viewed by users in the owner's organization.
Try contacting the owner of the form if you think this is a mistake.
BGP beta form is not working https://goo.gl/forms/6GS5phgPJGYaQxge2
You have to expect some things to be broken in a BETA ... This just started with the form.   🙂
Ben
Haha wonderfull when BETA fails at the form 😃
Hi All,
Hi
When can we expect BGP to be released as a feature to all Meraki MX router?
It seems that the BETA form is closed for new members. So are they any other way to get access to this?
Br.
John
I don't think this is the case. Update your MX to 14.x and call support they will turn it on.
