Issue connecting to non-meraki VPN peer networks
John25
Just browsing
Hi team,
Our network consists of 7 MX devices and is interconnected via the hub-spoke site-to-site VPN.
We have recently configured a non-meraki VPN peer on one of the hubs MX devices to a third-party router. I can ping the third-party router from the hub but I'm not able to ping it from other MX devices under the organization.
Is there any way I can use that single VPN tunnel for all MX devices under my organization or do I have to have a single tunnel created for each MX device?
Any leads would be appreciated.
2 Replies 2
You need a tunnel from every mx.
Or you need to put another device behind the hub that builds a tunnel. And then set a static route on the hub/advertise that static into the autvpn
This router must close a VPN tunnel with each MX, on the Meraki side you can use a single tunnel. You can achieve this using site tags.
https://documentation.meraki.com/MX/Site-to-site_VPN/Tag-Based_IPsec_VPN_Failover
