I have a large copy job and I noticed that maximum throughput is listed at 600Mbps. If I turned off some of the inspection services might it be possible to get closer to the 1Gbps? This is inside to outside traffic flow. Thank you.
Solved! Go to Solution.
As per the datasheet, 600mbps is the maximum throughput of the mx67. There's no way to increase it.
https://meraki.cisco.com/product-collateral/mx-family-datasheet/
No way, the maximum throughput is 600Mbps.
As a side note, some people have reported getting higher than the maximum on newer firmware with all security features turned off. Definitely not a validated and expected behaviour though.
https://community.meraki.com/t5/Security-SD-WAN/MX68CW-Maximum-WAN-troughput/m-p/187457#M43900
Thanks for the speedy replies.
If you put the slider to 600 ( which is the MAX ) It might go over 600Mbps.
If you set it to Maximum-1 , it will actually limit it to Max-1.
As Brash stated , some users have found that the MX are achieving speed higher than advertised ( as myself ).
