- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Inter vlan routing and static vs dhcp
Hi, I have a strange issue.
MX85 as a security appliance, also provides dhcp on a few vlans.
my main laptop on vlan 1 can generally see devices on other vlans.
I’ve plugged a smart device into a switch port that has a pvid of vlan 2.
if the device is set to DHCP I can see the webpage of the device from my laptop on vlan 1 without issue.
if I set the device to a static ip with exactly the same address, subnet, gateway, dns - I can PING the device from the laptop, but can’t access the devices webpage at the same address.
any ideas?
- Labels:
Other
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
hello,
Is the MX the DHCP server for vlan 2 as well? What kind of switch are you using? Any other devices performing layer 3 in the environment besides the MX? What if you plug the smart device straight into the MX and bypass the switch?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes, it’s running dhcp for all vlans.
they’re Engenius Switches, but no layer 3 functions.
not on site for a few weeks, so can’t do any physical changes to test.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Why don't you just make a DHCP reservation for this device instead of setting a static IP?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That’s fine but I’d like to understand where the problem lies.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are you sure you have configured the correct Gateway?
