Loss connection
KangDidin
Loss connection
hi all,
we had a problem when adding static arp to the mx-100, when adding there was no problem but when removing static arp the connection was lost for a while and then came back up, previously there was no problem when adding or removing static arp , has anyone experienced something like this, please provide input
7 Replies 7
Where can you add static arp on mx?
What did you set, where, and why?
KangDidin
Security & SDWAN > Configure > DHCP
Do you mean a static DHCP reservation?
KangDidin
yes
KangDidin
Previously there was no problem but after upgrading to MX version 18.107.2
CptnCrnch
Just to clarify: was the ARP entry done for a client on the MX? Or have you added the MX's MAC address to an upstream switch?
KangDidin
Yes, was the ARP entry done for a client on the MX
