If DNS_NAME.mydomain.com resolves to the public/wan IP of the MX and the port-forwarding is configured on the correct interface with the correct LAN info , that should work.
Do you have L7 rules that could block the return traffic ?
If you remove the allowed IPs in your portforwarding rule , can you test it with a simple online tool ( a.k.a ismyportOpen ? )
