In the case of Meraki's Auto vpn, the following port range is used to contact the VPN registries for the first time. After that, UDP communication is performed to each other's global IP using the following port range as the source. This uses UDP hole punching technology.
https://documentation.meraki.com/MX/Site-to-site_VPN/Meraki_Auto_VPN_-_Configuration_and_Troubleshoo...
Any devices sitting upstream of a WAN Appliance will need the following destinations whitelisted so the WAN Appliance can communicate with the Auto VPN registries:
Port
UDP 9350-9381
IP range for non-China cloud (meraki.com):
209.206.48.0/20
158.115.128.0/19
216.157.128.0/20
IP range for China cloud (meraki.cn):
43.192.139.128/25
43.196.13.128/25
Ports used for IPsec tunneling:
Source UDP port range 32768-61000
Destination UDP port range 32768-61000
I recommend the troubleshooting methods in this article.
https://community-meraki-com.translate.goog/t5/-/-/ba-p/194614?_x_tr_sl=ja&_x_tr_tl=en&_x_tr_hl=en&_...
