In Meraki Z1 & Z3 which LAN port works as secondary WAN port
Hi
Which LAN can we use as secondary WAN in Meraki Z1 or Z3 and how? As i have 2 internet up-links and i want when my primary uplink gets down than my secondary uplink starts working automatically. Please expedite support!
Accepted Solutions
Re: In Meraki Z1 & Z3 which LAN port works as secondary WAN port
I've just done a quick check on our devices. On the Z1, there is no secondary port you can setup as a secondary WAN port.
However, on the Z3, you can configure Port 2 as a secondary WAN.
11 REPLIES 11
Sorry but there is no dual WAN functionality in either the Z1 or the Z3. They're teleworker devices so not really designed with that kind of functionality in mind. I know the MX60, MX64, MX65 and MX84 all do dual WAN and of course the bigger devices for sure.
Edit: But the Z1 and Z3 do support 3G/4G failover via USB modem
Thank You for your kind reply but i also received following reply from one of the Technical Support member of CISCO Meraki:
I believe you would use LAN port 4, but the configuration is exactly the same. You'll need to connect to the local configuration page of the Z1 and change one of the ports to Internet/WAN instead of LAN. Please take a look at that piece of documentation I sent you.
https://documentation.meraki.com/MX-Z/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Prefer...
Kind regards,
James Earl
Cisco Meraki Technical Support
i have thoroughly studied the provided link but did not find any clear info as per claim of technical support member.
I think @mmmmmmark is correct.  The key bit from that page is:
"On all other MX models, a LAN port can be repurposed into an Internet port for use as WAN 2."
You don't have an MX - you have a Z.
Thanks for checking @Mr_IT_Guy That's very good to know!
Thank You Dear Mr_IT_Guy and to all others who has attended my inquiry and tried to solve it.
Have you test this configuration?
The Z3 brochure and the meraki support tell that the Z3 not have the secondary wan.
Thank
Regards
I can post screenshots tonight.
I started to post a screen shot and then saw you had posted already . . . duh
Who is the guy on the left?
Hi guys,
  I was checking my Wan connectivity on my Z1 and I also noted the Lan4 port setup :
z1_lan4
Not sure how does it behaves, but it's something we've being ask a lot!
