I'm new to the integration of AD and Meraki. Lucky, I was able to add my domain to meraki but I'm not able to apply my group policy to LDAP groups. I doubled check it by looking at the Network-wide>Clients. I tried to force my policy to the specific client to see if I configured the correct group policy and it worked.
I'm not sure if i've missed something on my AD but it shows "check" status in meraki.
I'm using MX84.
Thank you in advance!
Hi @guzgerardo
I understand if AD Integration is successful with Dashboard. We can MAP the AD Groups with Respective Meraki Group Policy and this shall work.
Kindly refer the following image for more information.
Also note that the client needs to be using the MX for its default gateway for this to work.
Thanks for the response. That's the same setup I've config.
I was not getting the rules to apply to AD users, then I checked in the documentation that in the "domain admin" field we don't need to enter the "domainname" before the user, after I removed it the rules were successfully applied to AD users.
I hope I have contributed
yes i've made the MX as default gateway.
Hi @guzgerardo
Is it possible for you to connect a PC directly to MX and Test?
Yes it's possible. Will have it test and revert soonest.
It is now working! Also tested it in MX ports. Knowing that I created incorrect switchport where the meraki was connected to the switch.
Additional question: what is the right way in activating Blocked/whitelisted url patterns? Should it be Append or Override?
