IPOE support?
Kiki
IPOE support?
Is there any clarity on when the MX series will start supporting IPoE?
https://community.meraki.com/t5/Feature-Announcements/IPv6-Support-on-MX-Security-amp-SD-WAN-Platfor...
Inderdeep
@Kiki : Not any update yet i expect will have first release in next year.
Regards/Inder
www.thenetworkdna.com
9 REPLIES 9
Inderdeep
Regards/Inder
Thank you!!!!!😀
Inderdeep
@Kiki : Welcome !
Regards/Inder
IPoE is just another name for DHCP.  Configure the MX WAN interface for DHCP and it will work.
@PhilipDAthSo no issues with switching a MX64 from PPPoE to IPoE\DHCP ? As we have an ISP that is dropping PPPoE
None.  It is usually better, as you get a clean 1500 byte MTU, rather than 1492 bytes with PPPoE.
Thanks @PhilipDAth , this worked for me when configuring a private router with PROXIMUS Belgian ISP for the configuration: Fiber line-> Internet Box -> Step 3. Establish WAN connection on your own router through IPoE session.
Details here: https://www.proximus.be/support/en/id_sfaqr_router_install/personal/support/internet/internet-at-hom...
xaviervalette
🎉 Happy new year all 🎉
In France, the ISPs (such as SFR) are authenticating DHCP request with an attribute (vendor-class-identifier),
Thus, without this option it is not possible for a MX to be in front of the ONT,
Any idea if it will be possible to add this option to the DHCP request on the MX ?
FYI, the option can be added on a linux machine this way :
Xavier VALETTE
