IMEI number for MX / Z3 devices
alexsh
Hello, does anybody know the way to retrieve from the dashboard IMEI numbers for MX68CW and Z3 Teleworker devices? Boxes are no longer available all devices are installed. We're switching LTE provider and number is require to preconfigure SIM's.
I'm not sure about MX, but for MG you can find it on local satus page > configure.
  • Configure
Configure section contains options for modifying bearer settings such as APN, PIN, and authentication. The ICCID of the SIM card and IMEI of the of the MG cellular gateway can also be found in this section as well. Safe Mode portion allows you to reconfigure port 1 into a WAN role for troubleshooting. To toggle the port 1 from default operating mode into "safe mode" on the MG, check the box to Enable Safe Mode and save.
2 Replies 2
  • Configure
alexsh
Perfect, just what I needed!
