I need to be able to export the routing table on Meraki MX appliance to an excel spreadsheet or CSV file
Just the force....erm API: https://dashboard.meraki.com/api_docs/v0#list-the-static-routes-for-an-mx-or-teleworker-network
It‘s a simply call, afterwards you can stuff these into whatever you‘d like (and whatever your programming language allows you to).
I just copy/pasted one from the dashboard into a Google sheet. Is this what you are after?
YES! Thats exactly what I was looking for. Thanks so much, Brandon! 🙂
