I need to be able to export the routing table on Meraki MX appliance
HaroldCabahug
I need to be able to export the routing table on Meraki MX appliance to an excel spreadsheet or CSV file
CptnCrnch
Just the force....erm API: https://dashboard.meraki.com/api_docs/v0#list-the-static-routes-for-an-mx-or-teleworker-network
It‘s a simply call, afterwards you can stuff these into whatever you‘d like (and whatever your programming language allows you to).
BrandonS
I just copy/pasted one from the dashboard into a Google sheet.  Is this what you are after?
HaroldCabahug
YES! Thats exactly what I was looking for. Thanks so much, Brandon!  🙂
