I can not reach s2s vpn from client vpn
I've Cisco Meraki MX84. I've s2s tunnel between me and my customer. In company i'm using 192.168.48.0/24 network and with this network i can reach other side of tunnel. But when i connect client vpn from home, it gives me an ip from 172.16.2.0/24 and i can not reach s2s vpn side. I tried to use static route but it throwed me this error;
"Static lan route subnets cannot be contained by (or be equal to) a client VPN subnet."
Can you please help me?
3 REPLIES 3
Re: I can not reach s2s vpn from client vpn
does the customer vpn know where 172.16.2.0/24 is.
No, actually i thought they don't need to know my vpn ip address. Should i need add it trusted ip list in customer s2s vpn configuration? I've 2 ssid in my company. 1 of them is giving from 10.0.1.X/24 and another one is hidden network, giving 192.168.48.X/24. When i connect from client vpn, i can reach 10.0.1.X/24 network, but i can go s2s vpn only 192.168.48.X/24. How can i go s2s vpn from client vpn? Do i need to use static route?
Have you added your client VPN subnet to your site-to-site VPN? It would need to be added to the Site-to-site VPN, and you would need to make sure that the site-to-site VPN firewall rules allow it to communicate across the site-to-site VPN the way you need it to.
