@ConnorL  is perfectly on point here. You should be seeing reCaptcha widget when you are on this page. See my step-by-step screenshots below, for reference:
This is often due to browser issues, temporary network problems, or extensions interfering with the process. Try another browser (possibly incognito mode) - to verify if this behavior is across different browsers. If you see this across different browsers, try using another ISP connection (or phone hotspot) for comparison.
	.ılı.ılı. Cisco Meraki
Network Support Engineer
### If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it ###
