- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
How to disable older TLS versions in the Meraki MX security appliances?
Meraki security appliance does not have an “SSL Decryption” setting in the dashboard. How can you enforce higher security standards to block older TLS versions. Ideally we would like to block all outdated TLS versions. I do believe Meraki does not provide a direct way to specify TLS versions in Layer 7 rules. Would like to get insight to see how this is possible.
Thank you!!
- Labels:
Firewall
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
With MX I believe you won't be able to do anything, you will probably need another solution or even another firewall.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
To add to @alemabrahao answer (which is correct), Cisco would recommend the use of Cisco Umbrella - which only supports TLSv1.2 clients.
Both Meraki MX and MR devices have native Umbrella integration options.
https://documentation.meraki.com/MX/Meraki_Umbrella_SDWAN_Connector/Deployment_Guide
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This is talking about 802.1x specifically.
