We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Hello, I have a problem with how to delete an organization because already have an organization,
Solved! Go to solution.
Screen Capture for what @Jhon explained.
You should go to Organization>Settings and at the end of that page you will see delete organization(in red). Make sure it has no networks, users, licenses, or devices claimed in its inventory so you can delete it successfully.
Thanks for All problem solved 🙂
