How to configure Guest SSID on MX68W
SCC
Hi All,
Please help to advise the steps required to configure the Guest SSID.
I can do by going in to SD-WAN --> Wireless Settings. But there is no option of Client IP assignment - NAT mode: use Meraki DHCP
I do not want Guest to connect to the LAN. Do i need to configure the separate VLAN for Guest and Map the Guest SSID to that new separate VLAN only ?
Yes New ssid and New vlan.
Then create firewall rules  that this vlan/subnet can not access your lan subnets. (Also possible  using a group policy  and attach it to the vlan.)
1 Reply 1
