How to check LAN intetrface config in MX64/MX450 Appliance ?
SarthakRane
Hello All,
Can we check the LAN interface config in the MX64 or Mx450 appliance ?
2 Replies 2
DarrenOC
Go to Security and SD-WAN > Configure > Addressing and VLANs.  You’ll see the MX LAN interface config here
tannermoreno
Hi SarthakRane
If you want to validate the port activation configuration and speed validation (10/100/1000) you can run it through Web Configuration
Or if you want to validate the logical settings (Vlans, IP Address, Mode Port [Trunk, Access]), you can run it through the Meraki dahboard, section Security & SD-WAN -> Addressing and Vlans.
I hope the information is useful to you.
Regards.
