Hi SarthakRane
If you want to validate the port activation configuration and speed validation (10/100/1000) you can run it through Web Configuration
Or if you want to validate the logical settings (Vlans, IP Address, Mode Port [Trunk, Access]), you can run it through the Meraki dahboard, section Security & SD-WAN -> Addressing and Vlans.
I hope the information is useful to you.
Regards.
