In routed mode, add the routes on Security & SD-WAN / Addressing & VLANs where you can set a gateway to the other network, sorry, post above was how to do it in concentrator mode.
Then on the other tab make sure to set VPN on under VPN settings for each network you want the other sites to know about.
