We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
I'd like to know whether this diagram works well or not.
1. Juniper ----- MX side, Does it work well ?
2. MX ------ MS side, Does it also work well ?
Do you have any experience to build as this diagram ?
Thank you,
Solved! Go to solution.
Get rid of this connection:
That connection can do bad things and Meraki has removed it from the recommended topology.
https://documentation.meraki.com/MX/Deployment_Guides/NAT_Mode_Warm_Spare_(NAT_HA)#Recommended_Topol...
Thanks,
Is everything good except for HA link ?
I will remove HA link between MX devices.
There appears to be alot missing from this diagram. Where are these MX devices located? A datacenter? In pass through mode you can not port channel the devices directly.
