- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Group policy - Allow URL list not functioning correctly
I have an MX64 with the latest firmware 16.16
In one of my Group Policies I have added "wetransfer.com" as well as "we.tl". Despite this I cannot access this website and get and error "website can't be found". If I plug a PC directly into my router bypassing the MX64 then wetransfer works perfectly.
I do have "All Web file sharing" enabled in the "Layer 7 firewall" settings, but the whitelist should overrule this setting right?
In "Blocked website categories" only "peer-to-peer" is blocked nothing else relating to file sharing is blocked.
Also in this specific group policy I'm blocking ports 50,000 to 65,535. Should this be a problem?
Thank you for any advice.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Whitelist is for content filtering. Not for layer7 firewall
P2p category can be tricky on 16.x nbar
Try to test without web sharing (if it does not help also try without p2p)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It works with web file sharing removed. This is unfortunate, as it severely limits the use of layer 7 rules.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes it would be better if it was also possible to make "allows"
You can still deny the more specific web file sharing applications, but you get a bigger list.
